Integrate CompanyCam + HubSpot
This Integration allows CompanyCam & HubSpot to communicate automatically. All Documents added in CompanyCam will sync to HubSpot automatically and a CompanyCam Project link will be available in HubSpot. Deals or Contacts created in HubSpot will create a Project in CompanyCam.
- You must have an active account with both CompanyCam and HubSpot in order to integrate the two services.
- You must have Admin Privileges in both CompanyCam and HubSpot in order to integrate the two.
What is HubSpot?
1. Create Contact or Deal in HubSpot.
1. Open CompanyCam On the left-hand side, under Resources, select Integrations.
2. Look for the HubSpot card under the different Integration options, Select the card and then click Connect.
3. Select Continue to link your Procore account to CompanyCam.
4. Next you will Log in with your HubSpot account.
5. Use your HubSpot credentials to log in and pick the company you are setting up.
6. Choose if you would like to have a new Deal or Contact create Projects in CompanyCam. 7. That's it! You are integrated. To make any changes select the Edit button.
If you need support integrating or have any issues with the integration reach out to support@companycam.com
- Don't see the integration you're looking for? Check out Zapier and their 5k+ partnering apps!
