Integrate CompanyCam + Knowify
This Integration allows CompanyCam & Knowify to communicate automatically. Automatically Create Projects in CompanyCam from a Job in Knowify. Once the two are linked you have quick access to all your CompanyCam photos in Knowify to save you and your team time and headaches!
- You must have an active account with both CompanyCam and Knowify in order to integrate the two services.
- You must have Admin privileges in both CompanyCam and Xcelerate in order to integrate.
What is Knowify?
Knowify empowers tradespeople and subcontractors with the tools and insights to manage their finances, teams, and Projects more effectively. Handle your budgeting, bidding, job costing, invoicing, and much more - all in one place!
Once Integrated, you have the option to create a new CompanyCam Project from a job in Knowify or link an existing Project in CompanyCam to a new Job in Knowify! Once the Job and Project are linked take your CompanyCam photos as normal and a linkout to CompanyCam will be available in Knowify. Now all your documentation is easily accessible in one place!
How to Create a CompanyCam Project from a Job in Knowify
How to view/ open a CompanyCam project from Knowify
How to share a CompanyCam project timeline with customers
If you need support integrating or have any issues with the integration reach out to support@knowify.com
Want to make work flows even easier? Now that you've got your CRM up and running, check out other
integration opportunities!
