Integrate CompanyCam + Zoho
This Integration allows CompanyCam & Zoho to communicate automatically. All Photos, added in CompanyCam will sync to Zoho instantly. You can choose to have Contacts, Deals, or Leads created in Zoho create a Project in CompanyCam allowing your job site photos to sync over to Zoho in real time!
- You must have an active account with both CompanyCam and Zoho in order to integrate the two services
- You can utilize the Integration during your 14-day CompanyCam Trial at no additional cost. Following that period the Integration is an additional 10$ a month for unlimited users added to your monthly Zoho bill.
- Paid CompanyCam and Zoho accounts are also required in order to utilize the Integration past your trial period.
What is Zoho?
Zoho powered by Digital Transformation Management is a unique and powerful CRM built to transform the way you work. Designed for companies of all sizes, built by a company that values your privacy.
Once enabled in the Zoho marketplace by going
here, the integration between CompanyCam and Zoho allows all your Photos taken in CompanyCam to sync over to your Zoho entries in real time! First, create your entry in Zoho whether that be a Contact, Deal, or Lead. Once created this will create a Project for that client inside of CompanyCam. Next, you just need to take your CompanyCam photos as normal inside of that Zoho created CompanyCAm Project and those photos will show up as attachments inside of the Zoho entry!
1. Create your Contact, Deal, or Lead in Zoho.
2. Find your matching CompanyCam Project for this entry.
3. Take your pictures.
4. Check the Zoho entry attachments and you should see those photos being sent over in real time!
CompanyCam + Zoho Integration Demo
This Integration was built and is supported by Digital Transformation Management. If you need support integrating or have any issues with the integration reach out to info@digitaltransformationmanagement.ai or to their phone support at +15613315360
Want to make work flows even easier? Now that you've got your CRM up and running, check out other
integration opportunities!
