Integrate CompanyCam + Contractor Foreman
This Integration allows CompanyCam & Contractor Foreman to communicate automatically. All Photos, Documents, and Photo Edits added in CompanyCam will sync to Contractor Foreman instantly. All Projects created in Contractor Foreman will create a Project in CompanyCam and vice versa to help you manage your workflow as you see fit!
- You must have an active account with both CompanyCam and Contractor Foreman in order to integrate the two services.
What is Contractor Foreman?
Contractor Foreman is the most affordable and easy-to-use construction management software serving contractors in 75+ countries! Make your next project a breeze with Contractor Foreman whether you are a general contractor, residential or commercial contractor, in the trades, and more!
Creating Projects with CompanyCam and Contractor Foreman is easy! When you create a Project in one system the Project details will be synced to the other system creating an entry in both programs. Once a Project has been created, take your Photos and upload Documents as you normally would in CompanyCam and you will see those sync over to Contractor Foreman in real time!
Create a new Project in CompanyCam
Create a new Project in Contractor Foreman:
1. Go to the Menu
2. Hover over the Project option (or click it) and click the + (new) icon.
3. Complete the required fields; Project Name, ID, Customer, Project Type. Fields not supported by the CompanyCam API will not transfer.
1. Go to the Menu
If you need support integrating or have any issues with the integration reach out to support@contractorforeman.com
- Don't see the integration you're looking for? Check out Zapier and their 5k+ partnering apps.
