Integrate CompanyCam + Procore
- You must have an active account with both CompanyCam and Procore in order to integrate the two services.
- Integrations are not available on Basic. Upgrade your plan to take advantage this feature.
- You must have Admin privileges in both CompanyCam and Procore.
What is Procore?
Procore is the all-in-one construction management software built to help you finish quality projects- safely, on time, and within budget.
Anytime that you add a new project in Procore, a new Project in CompanyCam will be created automatically. This CompanyCam Project will also have a Procore Label attached. If you add Photos or Documents to the CompanyCam Project they will automatically go back into the Procore project under Documents.
1. Open CompanyCam. On the left hand side, under Resources, select Integrations.
2. Look for the Procore card under the different Integration options, Select the card and then click Connect
3. Select Continue to link your Procore account to CompanyCam
4. Once you Continue, select the Black box titled Installed and Log in with Procore
5. This will then take you to Procore where you will select Allow
6. Confirm the Procore company you are setting up with the CompanyCam integration
7. That's it! You will now be connected. You should see the card update to Connected on the top right of the Procore card as well as options to update or delete the integration below once you select it.
If you need support integrating or have any issues with the integration reach out to support@companycam.com
