Integrate CompanyCam + Roofr
Roofr is a complete sales roofing software for roofers. From roof measurement reports to project-winning roofing proposals.
  • To start integrating the two, you need to have the Admin or Manager role. If you don’t have that role, ask an Admin on your company’s account for permission.
  • You must have an active account with both CompanyCam and Roofr in order to integrate the two services.
What is Roofr?
Roofr is a sales platform for the roofing industry that combines measurement report capability with a fast proposal system that powered by built-in estimation. Estimates are based on a pre-defined price list which automatically creates an estimate based on the completed measurement report.
Using Roofr with CompanyCam
How to create a Roofr Job from a CompanyCam Project and Sync Roofr Reports and Proposals to CompanyCam
Creating a Job and Automatically Uploading the Report to CompanyCam Documents
Uploading a Signed Roofr Proposal to CompanyCam Documents
How to Upload Images from CompanyCam to a Roofr Proposal
Authorization
If you need support integrating or have any issues with the integration reach out to support@roofr.com
  • Get measurements with Hover.
  • Create quotes with SumoQuote.
  • Organize project dates with TeamUp.
  • Map your project areas with DroneDeploy.
  • Don't see the integration you're looking for? Check out Zapier and their 5k+ partnering apps!
