Integrate CompanyCam + SalesRabbit
SalesRabbit is a Tool to help generate leads, manage and automate your outside sales process.
- To start integrating the two, you need to have the Admin or Manager role. If you don’t have that role, ask an Admin on your company’s account for permission
- You must have an active account with both CompanyCam and SalesRabbit in order to integrate the two services.
What is SalesRabbit?
SalesRabbit is the complete outside sales app. A sales enablement service and mobile CRM designed specifically for outside sales, including field sales and door-to-door sales teams. Their canvassing app provides solutions for lead tracking, lead management, and all your other field sales and d2d needs.
- Create a Project in CompanyCam when a SalesRabbit Form form is submitted.
- Upload Pictures to CompanyCam from SalesRabbit.
What data is transferred into CompanyCam?
Contact Details:- First Name
- Last Name
- Street Address
- Apt/Suite
- City
- State
- Postal Code
Integration Instructions and documentation. You will need your SalesRabbit login to access this documentation.
If you need support integrating or have any issues with the integration please reach out to SalesRabbit support using this form.
Want to make work flows even easier? Now that you've got your CRM up and running, check out other
integration opportunities!
- Don't see the integration you're looking for? Check out Zapier and their 5k+ partnering apps!
