Integrate CompanyCam + Arrivy
Arrivy Operations Cloud™ helps home service & delivery businesses provide deep customer engagement and real-time connectivity of operations.
- You must have an active account with both CompanyCam and Arrivy in order to integrate the two services.
What is Arrivy?
It's a platform that will help you drive business performance with enhanced reporting features. It keeps your customers engaged and internal teams aligned with text, email and instant messing tools. Get real time location and status updates directly in your dashboard. "Uber-ize" your customer experience with automated communications, live maps and instant chat. Save time with internal communications using automated job communications and team chats.
Set up a CompanyCam project to be created at a specific stage in your Arrivy workflow based upon your business operations. Take photos in the CompanyCam project and photos are then available to be added to any communications within Arrivy.
You'll need your login information to get to the setup link.
If you need support integrating or have any issues with the integration reach out to info@arrivy.com
