Edit Project Details
We know mistakes can happen when you're creating Projects. That's why you're able to edit those details, like name and address easily. Learn how below!
  • To edit project details, you need to have the AdminManager, or Standard role. If you don't have that role, ask an Admin on your company's account for permission; here's what they'll need.
  1. Log into CompanyCam.
  2. Find the Project you need to edit and click into it.
  3. Click on the three dots in the upper right corner of the Project and select Edit Project from the menu.
  4. Edit the necessary details then click Save Project.
  5. To add a Project Contact (your client/customer information) click the plus icon next to Contact Info on the right side panel. Add their name, phone number and email address then click Add Contact
  1. Open the CompanyCam app.
  2. Find the Project you need to edit and tap into it.
  3. Tap the three dots icon in the top right of the Project and select Edit Project Details from the menu.
  4. Edit the necessary details then tap Save Changes toward the bottom or Save in the top right corner.
  5. To add a Project Contact (your client/customer information) click Add Project Contact below the Project name. Add their name, phone number and email address then tap Add Contact.
