Integrate CompanyCam + PaintScout
PaintScout Helps You Be a Better Painting Contractor. PaintScout is an estimation, sales, proposal, invoicing and work order software for painting contractors designed for you to take your painting business to the next level.
- You must have an active account with both CompanyCam and PaintScout in order to integrate the two services.
What is PaintScout?
Paintscout is built For Painting Contractors to Succeed. Painting contractors have special needs, like prep times, paint volumes, work orders, colors, measuring by area, and so much more. PaintScout makes implementing all these variables a breeze.
When you have a proposal that is easy to understand and sells your company, your close rate goes up. PaintScout Web Proposals do just that and are easy to set up and send. Also, when you have the ability to give your team clear work orders, the job will get done right the first time. With PaintScout, you can give your crew clear and detailed work orders to set them up for success.
Simple Tools For Better Customer Experience PaintScout has tools like adding options, showing pictures and videos, customized pricing, grouping areas together and substrate view—PaintScout allows you to show your customer a more tailored estimate to suit their needs
Invoice and Get Paid. Instantly create and send invoices faster to secure payments quickly. With instant invoicing, you can also track payments from customers, staying on top of your business.
This integration brings selected photos from CompanyCam projects directly into PaintScout Estimates. Choose between original and annotated photos. They will be placed in the area or line item that you added them to. Photos will also be available in the media section of the estimate at the bottom.
Integration instructions and documentation
If you need support integrating or have any issues with the integration reach out to bryce@paintscout.com or use the Live Chat option at the bottom right of the PaintScout website.
- Don't see the integration you're looking for? Check out Zapier and their 4k+ partnering apps!
