Integrate CompanyCam + i360
improveit 360 is a cloud-based, flexible CRM solution specific to the home improvement industry.
- You must have an active account with both CompanyCam and i360 in order to integrate the two services.
- To start integrating the two, you must have the user permission "Manage Company Account". Don't have that ability? An Admin on your account can edit your permissions.
Setup instructions are in the PDF Document below. It's recommended that you download the PDF and then refer to the videos below for setup if you run into any trouble.
Install Package & Authorize
Project ID Field & VisualForce Pages
Link Field, Field Set, First Time Setup
Field Mapping, Permission Set, & Test
If you need technical assistance to set up the integration please contact Alex: alex.pickens@companycam.com.
NOTE: Depending on your request, fees may apply.
Want to make work flows even easier? Now that you've got your CRM up and running, check out other
integration opportunities!
