Integrate CompanyCam + OneClick Code
OneClick Code allows you to get accurate roofing codes, sales tax, and more at the click of a button. It's the first-ever application to verify address specific enforced roofing codes.
  • You must have an active account with both CompanyCam and OneClick Code in order to integrate the two services.
  • You must have Admin privileges in CompanyCam, you must use an admin email address when setting up the integration and you must be on the Pro plan to use this integration.
  • Integrations are not available on Basic. Upgrade your plan to take advantage this feature.
  • To start integrating the two, you need to have the Admin or Manager role. If you don’t have that role, ask an Admin on your company’s account for permission; here's what they'll need.
  • You must have Admin privileges in OneClick Code and you must be a Pro+ member to use this integration
Integrating CompanyCam + OneClick Code
If you need support during setup or have any issues with the integration please reach out to the OneClick Code support team here.
Want to make other workflows even easier? Now that you've got OneClick Code set up, check out our integration opportunities!
  • Get measurements with Hover.
  • Create quotes with SumoQuote.
  • Organize project dates with TeamUp.
  • Map your project areas with DroneDeploy.
  • Don't see the integration you're looking for? Check out Zapier and their 4k+ partnering apps!
Still need help? Contact Us Contact Us
