Manage and Remove Collaborators
- In order to manage and remove Collaborators, you will need the "Create and Modify User Accounts" permission enabled in your account.
- Once collaborators have been removed from a project, all of the photos and comments they’ve added to the project will remain. The collaborating company will also have a copy of the project on their account with everything they added and accessed during the time of collaboration. They can still add to that project, but you won’t be able to see it once the collaboration ends—and the same goes for you.
- Log in to CompanyCam.
- Open the project that has collaborators you’d like to manage or remove.
- Click on Collaborators below the Labels section.
4. Your Project Collaborators page will show you all active collaborators on the project. Click on the three dots on the collaborator you’d like to manage or remove.
5. Select End Collaboration if you’d like to remove the collaborating company completely from the project.
In the App
- Open the CompanyCam app on your phone or tablet.
- Open the project whose collaborators you’d like to manage or remove.
- Tap on the Collaborator icon below the project name.
4. Tap on the 3 dots to the right of the collaborator’s name that you’d like to remove.
5. Tap End Collaboration to remove the collaborator company completely from the project.
