Create Text Snippets
Finding yourself typing the same notes over and over? Let Text Snippets help you save time! Find out how to create them below.
- The Text Snippet feature is available on our Pro plan. Click here to upgrade today!
- You’ll need the permission settings to 'Access Company Reports' to use Text Snippets.
- You can create Snippets from a photo Description or a Report. We've broken down both ways on both web and in app.
Create a Text Snippet on the web
From a photo Description
- Log into CompanyCam and navigate to a Project with photos you need to work with.
- Click into a photo in the Project to view it.
- To the right of the photo you'll see Description. Click Edit or click into the text area.
- While in the editor for the Description click the Text Snippet button from the options.
- Already have a Description in the photo you want to use as a Snippet? Click Create new text snippet with content.
- In the pop-up click the + Create New button.
- Enter the title of the Snippet and all the details. Click Save when finished.
From a Report
- Log into CompanyCam and navigate to your Report you want to work in.
- In the Section Summary or in a photo text box click into the text area.
- Click the Text Snippet button or click Use a text snippet.
- Already have text for photo you want to use as a Snippet? Click Create new text snippet with content.
Create a Text Snippet in the app
- Open the CompanyCam app and navigate to one of your Projects.
- From the Project tap on a photo to view the photo.
- Tap Add a Description and use the Snippets button to access Snippets.
- Tap + Create New Snippet button at the bottom of the menu.
- Type in the title and the body of the Snippet. Tap Save when finished.
From a Report
- From the Project tap Reports and tap into the Report.
- Tap into a summary or a photo description area; tap Snippets.
- When editing a text snippet add your information then tap Save.
After creating text snippets, you can manage your saved snippets by editing or deleting any snippets you like!
