Change Login Information
Editing your login information, like your email or password, is easy to change in CompanyCam. You can change this on the web and the app!
On the Web
- Log in at CompayCam.
- Click on the User Profile on the left side panel and then click on My Settings from the dropdown menu.
- In the My Settings section, you can update your email login in the Email Address section. You can also update your password just below the email address in the Update Password section by typing a new password.
- Scroll down to and click on Save Changes at the bottom of the page before leaving to save your changes!
In the App
- Tap on your User Icon in the lower right corner.
- On your profile, tap on the arrow next to your name in the upper left corner.
- In the My Profile Info section, tap Edit and update your email.
- Tap Save in the upper right corner to save your changes before leaving.
*If you don't remember your login or password, click or tap on Forgot My Password on the sign in screen, enter your email address and we'll email you a link to reset your password.*
