Integrate CompanyCam + AtlasPro+
Integrate your Atlas Pro account with CompanyCam to easily sync your photos to your proposals.
NOTE: You must have an active account with both CompanyCam and AtlasPro+ in order to integrate the two services.
- Log in to your Atlas Pro account with your username and password by hovering over the Atlas Pro tab.
- Click the Connect with CompanyCam button on the CompanyCam banner to start the integration.
Select Authorize on the Authorization Required screen.
After you Authorize CompanyCam it will take you back to your AtlasPro dashboard.
Click Manage Leads to see your imported CompanyCam projects.
Click the plus (+) icon to the right of the Lead name to open the lead. Click Build Present Mode to see the photos in that project.
