Add Existing Photos on the Web
Have photos on your computer you'd like to add to a Project? Here's how:
  1. Login at app.companycam.com, open a Project or create a new Project* and click the blue Add Photos button (see below).
*Every photo is attached to a Project in CompanyCam.
2. Drag/drop or browse for the photos you'd like to add into CompanyCam. Select photos and hit enter.
*Note* When you add new photos, the app will pull the date-created information from the photos and organize them by this date. The photo you're uploading may be in an earlier part of the project feed depending on when it was taken.
Now that you've added photos to the project, you may want to add document files to the project. You can upload .pdf,.doc,.docx,.xls,.xlsx,.csv,.txt,.jpg,.jpeg,.png, and .numbers files. File size must be 100 MB or less.
