Edit and Add Drawings to Your Photos
Add Text, Icons, and Drawings to your Photos:
  1. Open the photo you want to edit by clicking on the photo.
  2. Then, click on the curved line icon at the top of the screen to open the Editor.
  • All tools are listed on the left side of your screen The annotation options are located in the upper 2/3, the editing options are located in the lower 1/3. In descending order, they are:
    •  Select
    • Draw
    • Poly Line
    •  Color
    • Thickness
    • Arrow
    • Circle
    • Square
    • Text
    • Timestamp
    • Sticker
    •  Rotate
    •  Crop
    •  Edit (Brightness, Contrast, & Saturation)
    •  Undo
    • Redo
  • When you're done, click the green checkmark to save in the upper right corner!
  1. Open the photo you want to edit by tapping on the photo.
  2. Then, click on the curved line icon in the bottom left of the screen to open the Editor.
  3. All tools are listed on the right side of your screen The annotation options are located in the upper 2/3, the editing options are located in the lower 1/3. In descending order, they are:
    • Color
    • Line Thickness
    • Draw
    • Poly Line
    • Arrow
    • Circle
    • Square
    • Text
    • Time Stamp
    • Sticker
    • Rotate
    • Crop
    • Edit (Brightness, Contrast, Saturation)
  4. When you're done, tap Save in the bottom right corner!
Want to use your edited photos in a before/after picture? Check out our help guide on creating Before/After photos through the Website & App!
These edited images are also ready to drop into Reports. If you click on the photo as you create or edit a report you can also bring up this edit tool!
