How to Download / Save Photos from CompanyCam
Your photos live on the cloud in CompanyCam, but if you need to save them else where you can always download the photos to save them! You can select how many photos you want to download:
In the Web App
Download the whole project:
- Sign into CompanyCam.
- Open the project you want to download photos from.
- Click Manage in the top right of the project.
- Choose Download All Photos from the drop down menu.
- Enter or check the email address the download email will go to.
- Choose what kind of files you want if edited.
- Original will be the photos how they were taken or uploaded.
- Modified will download with any photo edits/mark ups. *If photos aren't edited, you won't see this option.*
- Your download will go to your email or you can click the blue Download Photos in the browser.
Save multiple photos:
- Select the the first photo by clicking into the circle icon on the photo.
- Hold the Shift key and select the checkmark on the last photo (this will select everything in between).
- Click the Actions menu at the top of the page.
- Click Download.
Save photos from one day:
- Click the checkmark next to the date to select the photos.
- Click Download.
Save a single photo:
- Click the three dots icon in the upper right corner of the photo thumbnail.
- Click Download.
- The photo will download in your browser window and go to your computer's Downloads folder.
In the Mobile App
Auto save all photos taken in-app to your device
Photos will auto save when taken in the app when this is on. You do need to disable it if you no longer want them auto saved.
- Tap your user profile in the lower right corner, then tap the gear icon in the upper right corner to access the App Settings.
- Tap on Camera, then scroll to Save Images to Device.
- Tap the toggle to the right to On/Off to enable or disable
Select photos to save to your device
- Open a Project and tap View All in the Photos section.
- Tap the Select Photos icon in the upper right corner next to the filter icon.
- Tap the photos you want to download to select them. A blue circle with a check mark should appear in the upper left corner of the photo tiles to show they're selected. Tap the three dots icon in the bottom right corner. Choose Save to Device to save the photos to your camera roll.
Other options
- Looking for a shorter way to rename your photos in CompanyCam? Learn how you can use tags to rename downloaded photos!
- Need hard copies of your photos? Check out our help guide on how to print photos from the CompanyCam website!
