How to Use Notifications
In the Mobile App—
How to Send a Notification:
1. Open any project or photo, tap Add project comment at the bottom of the screen
2. Use @ to mention another user, tag multiple users if you need to, then tap Post
3. Tap any photo and tap the conversation bubble at the bottom left corner
4. Once in the photo comment, tap on the @ symbol to mention another user, then tap on Post
@Mentioned users will receive an immediate notification.
How to View a Notification:
1. In the app, you'll see a notifications bell in the bottom right corner of the Home Screen; tap the bell to view notifications.
2. Tap on the message to open and respond.
How to Set your Notification Settings on Mobile:
1. Tap your user profile in the lower right corner, then tap the gear icon in the upper right corner to access the app settings
2. Once in the app settings, tap on Notifications
3. You can enable/disable when you would like to receive notifications in the app here
*Note* You will always receive a notification if someone mentions you; this cannot be turned off.
On the Computer—
1. Open any photo or project and in the comment field use @ to mention another user.
2. Tap 'Post' to save this comment, and the user will receive an immediate notification.
1. In the app, you'll see a red circle on the notifications icon. Tap to view notifications.
2. Select the message to open and respond.
How to Set your Notification Settings on the Web:
1. Change Notification settings by selecting "Update Notification Settings"
2. Choose how you would like to be notified
