Integrate CompanyCam + JobProgress
You must have an active account with both CompanyCam and JobProgress in order to integrate the two services. New to JobProgress? Sign up here
TO GET STARTED, LOG IN TO COMPANYCAM:
1. Log in at app.companycam.com, hover over your user icon (upper right) and choose 'Integrations'
2. Click 'Access Tokens' and then click 'New Token'
3. Select 'JobProgress' from the drop-down and leave the box UNCHECKED! Click Create Token.
4. Highlight the Token and Copy (you'll paste this into JobProgress!)
NOW, LOG IN TO JOBPROGRESS:
5. Log in at www.jobprogress.com/app, click in the upper right corner for the drop-down menu and choose 'Settings'
6. Navigate to your Company Settings > Partnerships > Connect CompanyCam.
8. Paste in your Token (that you copied from your CompanyCam account) & click 'Connect CompanyCam'
AND YOU'RE DONE!
Now, photos that you take in CompanyCam will automatically be in JobProgress too!
