Create a Project without a Street Address
Here's how to create the project using the GPS coordinates vs. the street address.
At the job site with the Mobile App:
1. Open your app and tap Create Project at the top left or tap the Camera icon at the bottom of the screen
2. Move the Map around until the GREEN PIN is exactly where the Project is located and tap Create in the bottom right corner
3. Enter project name and details, then tap on Create in either the upper right corner or bottom middle of screen
From the office with the Web App:
1. Login at app.companycam.com
2. Choose New Project to the right below your user icon to the right
3. Select Place a Pin
4. Use the search field at the top left to get in the general area - Search a highway name, intersection, nearby business, etc
5. Drag the pin to the exact position for the Project
6. Edit the Project information fields on the right, and then click Create Project
After you create a project using GPS Coordinates, any user can arrive at the job site and they will see this project in the nearby projects list.
