Edit User Permissions
When adding a new user to your CompanyCam account, that user by default will have the 'Standard Access' permissions.
*At this time you are only able to edit users from the web application.*
Here's how to customize a User's permissions —
1. Log in on the web at: app.companycam.com and choose Users from the menu at the top of the screen.
2. Click on the 3 dots in the upper right corner of the user's card you wish to change and select Edit.
3. Customize the User's permissions by turning each option on or off.
4. *Note* There are preset options available. Click the drop-down arrow to select Admin, Standard Access or Restricted Access. [The image below is a closeup of the drop-down menu.]
