Using CompanyCam as a Guest User
When a company adds you as a guest user in CompanyCam, you will receive a text message as well as an email with a link to access the project. Follow the steps here to add photos and/or notes from the computer or your mobile device.
- To access the project, you must always access via the link either in your text message or email.
1. Click the project link in the email that you received.
2. Enter your email address to verify yourself as Guest User.
3. Choose Add Photos (pink arrows) or Add Note (yellow circle).
Text Message
1. Click the link in the text message that you received.
2. Enter your email address and tap Verify.
3. Tap Add Photos or Add Note as needed.
