Integrate CompanyCam + SuccessWare 21
Our Smart Photos and SuccessWare’s business management platform work seamlessly together to help your business run smoothly and stay organized. Photos and tags in CompanyCam are easily searchable, making it easy for you to keep everything clear!
What is SuccessWare 21?
  • A complete business management software solution built for residential HVAC, Plumbing and Electrical contractors. With built-in accounting, customer and job management, dispatch, marketing and agreement management, SuccessWare is the complete solution for today’s contractor. Our mobile field service solution, SuccessWare Mobile, allows your techs to timestamp, invoice and process payments directly from their mobile device.
Connecting the integration
  1. Log in to CompanyCam and head to the Integrations page in CompanyCam.
  2. Click on Access Tokens.
  3. Click on New Token
  4. Select SuccessWare from the dropdown menu. Leave the checkbox UNCHECKED so that the Access Token has Read and Write permissions. Click on Create Token.
  5. Once the Token is created, copy and paste the Access Token into the SuccessWare Access Token Field.
  6. Beyond this point, you will need to head to SuccessWare and finish the sign-up process.
  7. Follow the video instructions to complete setup: https://www.youtube.com/watch?v=A8mOMNCofss
  8. If you have any questions regarding the SuccessWare side of the integration, you can reach out to Michelle at: mzimmermann@successware21.com
  • Get measurements with Hover.
  • Create quotes with SumoQuote.
  • Organize project dates with TeamUp.
  • Map your project areas with DroneDeploy.
  • Don't see the integration you're looking for? Check out Zapier and their 3k+ partnering apps!
