Integrate CompanyCam + SuccessWare
- Sign into your CompanyCam account on the web. Hover over your user profile in the upper right, then click on Integrations
- Click on Access Tokens
- Click on New Token
- Select SuccessWare from the dropdown menu. Leave the check box unchecked so that the Access Token has Read and Write permissions. Click on Create Token
- Once Token is created copy and paste the Access Token into the SuccessWare Access Token Field
- Beyond this point you will need to head to Successware and finish the sign up process.
- Below is a link to a video to show you how to finish the setup.
Video: https://www.youtube.com/watch?v=A8mOMNCofss
If you have any questions regarding the SuccessWare side of the integration you can reach out to Michelle at: mzimmermann@successware21.com
