Integrate CompanyCam + Job-Dox
With the Job-Dox and CompanyCam integration, you can easily take photos in the field with CompanyCam and have the photos automatically sync to your Job-Dox Project! Job-Dox allows you better control of your business with slick automated tools to help you manage daily tasks.
- Before integrating, you'll need to have an active account with Job-Dox and CompanyCam.
Connecting the integration
Generate an Access Token in CompanyCam
1. Log in to CompanyCam, Click 'Integrations' at the bottom of the left menu.
2. Click ' Access Tokens'.
3. Click New Token.
4. Select Job-Dox from the drop-down list; leave the check box unchecked, then click on Create Token.
5. Copy the token so that you can paste it into Job-Dox.
Paste the Access Token in Job-Dox
5. Log in to your Job-Dox account and click the 'App Drawer' icon near the top right.
6. Click 'Settings'. Once you are in the 'Settings' section, click the 'CompanyCam' button on the left. Your menu options may look different than this screen shot, based on what features you have turned on.
7. Click the checkbox to enable the integration. Enter your CompanyCam email address (username) and the Access Token that you generated in your CompanyCam account. Click 'Save'.
Validate your integration
Once you click 'Save', Job-Dox will attempt to validate the access token. If there is a problem with of the information you provided, the status will update to "Failed" and you can try again after double-checking your username and access token. Otherwise, it will say "Active".
To test the integration, go create a new project in Job-Dox. If you go to the 'Photos' section of Job-Dox, you will see a new Album entitled "CompanyCam". Opening that album will also give you a link to that project IN CompanyCam in the top-right corner.
Note: Chat with our Support team or email us at support@companycam.com and let us know if you have any questions!
Interested in other CRM’s and integration partners CompanyCam has that can help make your workflows even faster? Check out our partner network page to view all of our current integration options!
Ready to get another integration set up? Check out our easy to use help guides for the integrations you’re ready to hook up on our help site!
