How to Customize Your Home Screen in the Mobile App
Create the perfect home screen layout that works best for you! Select the items you want to see and turn off the ones you don't. You can reorder everything as well.
Home Screen Items Include:
· Nearby Projects
· My Feed
· Company Feed
· Starred People
· Starred Projects
1. Open the Mobile App & swipe up until you reach the bottom of the screen
2. Tap Customize Home Screen in the lower left
3. Tap the checkmarks on the left to turn items ON/OFF.
Tap and drag the menu icons on the right to reorder the active items.
Tap the x in the upper left to go back to the Home Screen.
