Integrate CompanyCam + iRestore
"Our vision is that iRestore is your complete solution to operating your company by serving the individuals and team while supporting excellence in service." - iRestore
First off, you will need to have an active account with iRestore and CompanyCam
Please follow the instructions linked below to integrate:
Integration Instructions
After you set up the integration test it by creating a new "Job" in iRestore. That job should sync into CompanyCam as a new "Project".
To sync the records moving forward you will have to create them in iRestore first.
