Create a New Project in the Mobile App
1. Open CompanyCam
2. Tap Create Project icon (upper left)
3. If the suggested address is correct, tap Create (bottom right).
If the suggested address is NOT correct, use the search box at the top of the screen and select from the suggestions that populate.
4. Add a Project Name
5. Tap Create
Do you need to create a project from a computer? Check out this tutorial:
Create a New Project on the Web App
