How to Create a Report
  • Log in at app.companycam.com
  • Hover over each photo thumbnail and click the check mark circle (upper left corner of each photo) to select the photos
  • Choose Reports (top of your screen)
  • Choose Create New Report
On the right you will find a series of options to customize your report and to share it (see below).
  • Click on Generate PDF to have your Report in PDF format. Click on Download PDF to download the PDF file in your computer. Click on Preview PDF at the bottom right corner to see what the PDF will look like.
  • Click on Share Report to create a link that you can share on Facebook, Twitter and Email, or anywhere you'd like by clicking on Copy Link
  • Click on Rearrange Items on your right. A layout bar showing the order of your pictures in the report will appear. Click, drag and rearrange the pictures in the left bar to change the order in which they appear in the report.
  • Click on Photo Detail Settings on the right side to decide what details about your pictures you would like to include in the report. Then click on Update Settings
  • Click on Load All Photo Comments to display the comments of you pictures under the notes section of your report
  • To add text to your report click on Add Note to the right of every picture - You can also add text by clicking on Add a text Block
  • Lastly, click on View Report at the top right to see your Report - this is what the recipient of a link will see when you share it with them.
